Other Parts Discussed in Thread: OPT3001, OPT3007,
We procured OPT3001 EVM for our research project.
I would like to know how to read the Light Sensor reading from a C / C++ program on Windows and Linux connected via USB.
Can you help me with a sample application/SDK to integrate into our project?
I tried using HID API and I see the following results
#include <stdio.h> #include <wchar.h> #include <string.h> #include <stdlib.h> #include "hidapi.h" // Headers needed for sleeping. #ifdef _WIN32 #include <windows.h> #else #include <unistd.h> #endif int main(int argc, char* argv[]) { (void)argc; (void)argv; int res; unsigned char buf[256]; #define MAX_STR 255 wchar_t wstr[MAX_STR]; hid_device *handle; int i; struct hid_device_info *devs, *cur_dev; printf("hidapi test/example tool. Compiled with hidapi version %s, runtime version %s.\n", HID_API_VERSION_STR, hid_version_str()); if (hid_version()->major == HID_API_VERSION_MAJOR && hid_version()->minor == HID_API_VERSION_MINOR && hid_version()->patch == HID_API_VERSION_PATCH) { printf("Compile-time version matches runtime version of hidapi.\n\n"); } else { printf("Compile-time version is different than runtime version of hidapi.\n]n"); } if (hid_init()) return -1; devs = hid_enumerate(0x0, 0x0); cur_dev = devs; while (cur_dev) { printf("Device Found\n type: %04hx %04hx\n path: %s\n serial_number: %ls", cur_dev->vendor_id, cur_dev->product_id, cur_dev->path, cur_dev->serial_number); printf("\n"); printf(" Manufacturer: %ls\n", cur_dev->manufacturer_string); printf(" Product: %ls\n", cur_dev->product_string); printf(" Release: %hx\n", cur_dev->release_number); printf(" Interface: %d\n", cur_dev->interface_number); printf(" Usage (page): 0x%hx (0x%hx)\n", cur_dev->usage, cur_dev->usage_page); printf("\n"); cur_dev = cur_dev->next; } hid_free_enumeration(devs); printf("enum done \n"); // Set up the command buffer. memset(buf, 0x00, sizeof(buf)); buf[0] = 0x01; buf[1] = 0x81; // Open the device using the VID, PID, // and optionally the Serial number. ////handle = hid_open(0x4d8, 0x3f, L"12345"); handle = hid_open(0x451, 0x2f90, NULL); if (!handle) { printf("unable to open device\n"); return 1; } // Read the Manufacturer String wstr[0] = 0x0000; res = hid_get_manufacturer_string(handle, wstr, MAX_STR); if (res < 0) printf("Unable to read manufacturer string\n"); printf("Manufacturer String: %ls\n", wstr); // Read the Product String wstr[0] = 0x0000; res = hid_get_product_string(handle, wstr, MAX_STR); if (res < 0) printf("Unable to read product string\n"); printf("Product String: %ls\n", wstr); // Read the Serial Number String wstr[0] = 0x0000; res = hid_get_serial_number_string(handle, wstr, MAX_STR); if (res < 0) printf("Unable to read serial number string\n"); printf("Serial Number String: (%d) %ls", wstr[0], wstr); printf("\n"); // Read Indexed String 1 wstr[0] = 0x0000; res = hid_get_indexed_string(handle, 1, wstr, MAX_STR); if (res < 0) printf("Unable to read indexed string 1\n"); printf("Indexed String 1: %ls\n", wstr); // Set the hid_read() function to be non-blocking. hid_set_nonblocking(handle, 1); // Try to read from the device. There should be no // data here, but execution should not block. res = hid_read(handle, buf, 17); // Send a Feature Report to the device buf[0] = 0x2; buf[1] = 0xa0; buf[2] = 0x0a; buf[3] = 0x00; buf[4] = 0x00; res = hid_send_feature_report(handle, buf, 17); if (res < 0) { printf("Unable to send a feature report.\n"); } memset(buf, 0, sizeof(buf)); // Read a Feature Report from the device buf[0] = 0x2; res = hid_get_feature_report(handle, buf, sizeof(buf)); if (res < 0) { printf("Unable to get a feature report.\n"); printf("%ls", hid_error(handle)); } else { // Print out the returned buffer. printf("Feature Report\n "); for (i = 0; i < res; i++) printf("%02hhx ", buf[i]); printf("\n"); } memset(buf, 0, sizeof(buf)); // Toggle LED (cmd 0x80). The first byte is the report number (0x1). buf[0] = 0x1; buf[1] = 0x80; res = hid_write(handle, buf, 17); if (res < 0) { printf("Unable to write()\n"); printf("Error: %ls\n", hid_error(handle)); } // Request state (cmd 0x81). The first byte is the report number (0x1). buf[0] = 0x1; buf[1] = 0x81; hid_write(handle, buf, 17); if (res < 0) printf("Unable to write() (2)\n"); // Read requested state. hid_read() has been set to be // non-blocking by the call to hid_set_nonblocking() above. // This loop demonstrates the non-blocking nature of hid_read(). res = 0; while (res == 0) { res = hid_read(handle, buf, sizeof(buf)); if (res == 0) printf("waiting...\n"); if (res < 0) printf("Unable to read()\n"); #ifdef WIN32 Sleep(500); #else usleep(500 * 1000); #endif } printf("Data read:\n "); // Print out the returned buffer. for (i = 0; i < res; i++) printf("%02hhx ", buf[i]); printf("\n"); hid_close(handle); /* Free static HIDAPI objects. */ hid_exit(); #ifdef WIN32 system("pause"); #endif return 0; }
Device Found
type: 0451 2f90
path: \\?\hid#vid_0451&pid_2f90#6&2c7c3956&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
serial_number: (null)
Manufacturer: (null)
Product: (null)
Release: 1111
Interface: -1
Usage (page): 0xa5 (0xffa0)
The device is opened, but we don't get any other details.
Ideally, we need to read the LUX values from the sensor. Can you assist with a sample application for the same
