AWR1843BOOST: WARM RESET
Part Number: AWR1843BOOST
I am using AWR1843BOOST module, till now i was able to work fine on board, but now on power on of device i see WARM RESET LED glowing and module is unable to response.
I don't understand the problem and how to solve it.
-Tirthraj Solanki
  • Hello Tirthraj,
    Can you provide some more details about how you are using the board? Are you using it in standalone, or with boosterpack, or any other TI EVMs?
    The Warm Reset can be driven by the PMIC, so there could be an issue with the PMIC or pre-regulator. Can you probe the output voltages of the PMIC and pre-regulator to confirm if they are at the expected levels?
    Adrian
  • Hi Adrian,
    You were right, it was power supply issue.
    Changing the power supply my module is working fine.
    Thank you.
    -Tirthraj
