I am checking the data sheet of DRV5021Q1.
I don't know the HIGH level output voltage from the sensor.
How many volts will be output when the power supply voltage is set to 5V?
Thank you for reaching out with your question. DRV5012Q1 has an open drain output and requires a pull-up resistor. Therefore, the HI state on the output will be VCC. It is not recommended to use a different voltage for the pullup than VCC.
