It consists of AWR6843ISK-ODS Antenna 、 MMWAVEICBOOST and DCA1000.
I started MMWAVE studio and became time out I triger start.
It became not rader capture when I did postprocessing
test connecting log
GM: Constructor
GM: Tue Nov 09 14:48:11 2021
RSTD.Transmit("/Settings")
[14:48:12]
[14:48:12] ### Running Startup script: "C:\Program Files (x86)\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Scripts\Startup.lua" ###
[14:48:12] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[14:48:12] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[14:48:12] Scripter ignored: Attempt to UnBuild() again or before Build.
[14:48:12] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\Program Files (x86)\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[14:48:12] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[14:48:12] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[14:48:12] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[14:48:12] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[14:48:12] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[14:48:12] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\Program Files (x86)\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\RunTime\\SAL.dll")
[14:48:12] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[14:48:12] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[14:48:12] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[14:48:12] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[14:48:12] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[14:48:12] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[14:48:12] RSTD.Transmit("/")
[14:48:12] RSTD.SaveSettings(): Settings saved to "C:\Users\ttrpc009\AppData\Roaming\RSTD\config.xml"
[14:48:12] RSTD.Build()
[14:48:12] RSTD.AL_Build()
[14:48:12] RSTD.AL_LoadXml()
[14:48:12] RSTD.AL_Init()
[14:48:12] RSTD.Clients_Build()
[14:48:12] GM: Init
[14:48:12] GM: Loaded 'C:\Program Files (x86)\ti\mmwave_studio_02_01_00_00\mmWaveStudio\Clients\\LabClient.dll'
[14:48:12] GM: 1 Guest (s) init
[14:48:12] GM: 1 Module(s) init
[14:48:12] GM: 2 Tab (s) init
[14:48:12] RSTD.Client_LoadXml()
[14:48:12] [RadarAPI]: ar1.selectRadarMode(0)
[14:48:12] [RadarAPI]: Status: Passed
[14:48:12] Matlab Runtime Engine is installed
[14:48:12] [RadarAPI]: Starting Matlab Engine..
[14:48:19] [RadarAPI]: Matlab Engine Started!
[14:48:21] [RadarAPI]: ar1.selectCascadeMode(0)
[14:48:21] [RadarAPI]: Status: Passed
[14:48:21] [RadarAPI]: ar1.LoadSettings('C:\Users\ttrpc009\AppData\Roaming\RSTD\ar1gui.ini')
[14:48:21] TESTING = false
[14:48:21] RstdNet: Port 2777: Listening..
[14:48:21]
[14:48:21] ***Script completed successfully.***
[14:48:25] [RadarAPI]: Opening Gpio Control Port()
[14:48:25] [RadarAPI]: Status: Passed
[14:48:26] [RadarAPI]: Opening Board Control Port()
[14:48:26] [RadarAPI]: Status: Passed
[14:48:27] [RadarAPI]: ar1.FullReset()
[14:48:27] [RadarAPI]: Status: Passed
[14:48:28] [RadarAPI]: Closing Board Control Port()
[14:48:28] [RadarAPI]: Status: Passed
[14:48:28] [RadarAPI]: Closing Gpio Control Port()
[14:48:28] [RadarAPI]: ar1.SOPControl(2)
[14:48:29] [RadarAPI]: ar1.Connect(4,115200,1000)
[14:48:30] [RadarAPI]: ar1.Calling_IsConnected()
[14:48:32] [RadarAPI]: ar1.SelectChipVersion("IWR6843")
[14:48:32] [RadarAPI]: Status: Passed
[14:48:32] [RadarAPI]: ar1.frequencyBandSelection("60G")
[14:48:32] Device Status : IWR6843/QM/SOP:2/ES:2
[14:48:32] [RadarAPI]: ar1.SaveSettings('C:\Users\ttrpc009\AppData\Roaming\RSTD\ar1gui.ini')
[14:48:34] [RadarAPI]: ar1.DownloadBSSFw("C:\\Program Files (x86)\\ti\\mmwave_studio_02_01_00_00\\rf_eval_firmware\\radarss\\xwr68xx_radarss.bin")
[14:48:34] [RadarAPI]: Downloading BSS ROM RPRC Binary..
[14:49:19] [RadarAPI]: ar1.GetBSSFwVersion()
[14:49:19] [RadarAPI]: BSSFwVersion:(06.02.00.06 (22/08/19))
[14:49:21] [RadarAPI]: ar1.DownloadMSSFw("C:\\Program Files (x86)\\ti\\mmwave_studio_02_01_00_00\\rf_eval_firmware\\masterss\\xwr68xx_masterss.bin")
[14:49:21] [RadarAPI]: Downloading MSS RPRC Binary..
[14:49:40] [RadarAPI]: ar1.GetMSSFwVersion()
[14:49:40] [RadarAPI]: MSSFwVersion:(02.00.00.03 (27/08/19))
[14:49:41] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[14:49:41] [RadarAPI]: Status: Passed
[14:49:42] MSS power up done async event received!
[14:49:43] [RadarAPI]: ar1.SelectChipVersion("IWR6843")
[14:49:43] [RadarAPI]: Status: Passed
[14:49:43] Device Status : IWR6843/QM/SOP:2/ES:2
[14:49:43] [RadarAPI]: ar1.RfEnable()
[14:49:43] BSS power up done async event received!
[14:49:44] [RadarAPI]: ar1.GetMSSFwVersion()
[14:49:44] [RadarAPI]: MSSFwVersion:(02.00.00.03 (27/08/19))
[14:49:44] [RadarAPI]: ar1.GetBSSFwVersion()
[14:49:44] [RadarAPI]: BSSFwVersion:(06.02.00.06 (22/08/19))
[14:50:00] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 2, 0)
[14:50:00] [RadarAPI]: Status: Passed
[14:50:02] [RadarAPI]: ar1.LPModConfig(0, 0)
[14:50:02] [RadarAPI]: Status: Passed
[14:50:04] [RadarAPI]: ar1.RfInit()
[14:50:04] RF Init async event received!
[14:50:04] [RadarAPI]: Status: Passed
[14:50:04] [RadarAPI]: Time stamp, Temperture: 20421,56; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 0, 0; HPFcutoff Status, Update: 0, 0; LPFcutoff Status, Update: 0, 0; PeakDetector Status, Update: 0, 0; TxPower Status, Update: 0, 0; RxGain Status, Update: 0, 0; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 0, 0;
[14:50:11] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[14:50:11] [RadarAPI]: Status: Passed
[14:50:20] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[14:50:20] [RadarAPI]: Status: Passed
[14:50:21] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[14:50:21] [RadarAPI]: Status: Passed
[14:50:23] [RadarAPI]: ar1.ProfileConfig(0, 60, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 131072, 30)
[14:50:23] [RadarAPI]: Status: Passed
[14:50:25] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[14:50:25] [RadarAPI]: Status: Passed
[14:50:26] Test Source Already Disabled...!!!
[14:50:26] [RadarAPI]: ar1.DisableTestSource(0)
[14:50:26] [RadarAPI]: Status: Passed
[14:50:26] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
[14:50:29] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[14:50:29] [RadarAPI]: Sending dll_version command to DCA1000
[14:50:29] DLL Version : 1.0
[14:50:29] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[14:50:29] [RadarAPI]: Status: Passed
[14:50:35] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[14:50:35] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[14:50:35] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[14:50:36] [RadarAPI]: Sending fpga command to DCA1000
[14:50:36] FPGA Configuration command : Success
[14:50:36] [RadarAPI]: Sending record command to DCA1000
[14:50:36] Configure Record command : Success
[14:50:36] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[14:50:36] [RadarAPI]: Sending fpga_version command to DCA1000
[14:50:36]
[14:50:36] FPGA Version : 2.7 [Record]
[14:50:36]
[14:50:42] [RadarAPI]: ar1.CaptureCardConfig_StartRecord("C:\\Program Files (x86)\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
[14:50:42] [RadarAPI]: Sending start_record command to DCA1000
[14:50:43] [RadarAPI]: ar1.StartFrame()
[14:50:43] [RadarAPI]: Status: Passed
[14:50:43] Frame start async event received!
[14:50:43] [RadarAPI]: Frame Ended
[14:52:02] [RadarAPI]:
[14:52:02] Start Record command : Success
[14:52:02]
[14:52:02] Record Process :
[14:52:02] Timeout Error! System disconnected
[14:52:02]
[14:52:02] Record stop is done successfully
[14:52:02] Frame End async event received!
[14:52:02] [RadarAPI]: ar1.StartMatlabPostProc("C:\\Program Files (x86)\\ti\\mmwave_studio_02_01_00_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[14:52:02] [RadarAPI]: No of files Captured: 4, Total no of frames for each device : 8
