Other Parts Discussed in Thread: TPS82130
We have a few TMP275 sensors spread around in a system, connected by wires, and powered by a 5v TPS82130 (powering also some other relatively light loads).
What should be the 5v PS specifications (noise/ripple), to get reliable repeatable measurements ?
The reason for asking:
- On all systems, when changing system modes, we have significant temperature reading jump (often 1-1.5 degrees, sometimes more).
- On some systems we encounter sensors providing noisy readings.
The source for (at least the jumps):
- Reading jumps come from the 5v supply (can be improved or eliminated by manipulations of the 5v supply (e.g. connecting another PS, filtering, loading).
- Probing the 5v we see some ripple/noise which is originally about 150 mv (and may very slightly change for different system modes) .
DS does say accuracy is 1.5 degrees for 3.3 - 5.5v supply, but also specify repeatability of 0.06 degrees. there is no PSRR data in the DS.
