Other Parts Discussed in Thread: AWR6843AOP, AWR6843AOPEVM
For In Cabin monitoring application for AWR series what is accuracy of Vital sign detection ?
HI, there:
The accuracy of the vital sign detection is related how stable the test keep his position relative to the sensor. For the current vital sign + in-cabin sensing demo, the performance is not very good. So we have decided not to support those demos any more. If you want to check the vital sign performance, you can find the latest ones at:
Zigang
Thanks for reply Zigang Yang. We will use it and incase of need any support will post it here. Still do you have any tentative figure of accuracy for Vital signal detection?
Also, Which AWR module you prefer to work this demo for in cabin monitoring- Occupancy, Heart rate, Respirations rate & Child presence? Can temperature measure using this?
I found some slides on our vital sign accuracy:
And this result is based on the latest vital sign demo at https://dev.ti.com/tirex/explore/node?node=A__ANQFjINyZ2YdSLVBPxylNw__com.ti.mmwave_industrial_toolbox__VLyFKFf__LATEST. You can try this demo with AWR6843AOP EVM board.
You can also try xWR6843 vital sign demo at
Where any xwr6843 EVM is supported and only one antenna is used.
So far, we do not have one demo that monitoring- Occupancy, Heart rate, Respirations rate & Child presence at the same time. For best vital sign performance, it is better to mount the sensor in front of the chest. For best car coverage for occupancy (2 row and footwell), usually we prefer the overhead mounting. So, you will need to tradeoff performance vs coverage if you want to monitoring occupancy as well as vital sign monitoring.
Zigang
Thanks for reply Zigang Yang again. Looks promising information. Can we measure body temperature or Dehydration kind of signs using this sensor? if yes. then what will be logic behind it? Now we are planning to procure AWR6843AOPEVM Evaluation board for quick start.
Hi, Ajinkya:
So far, we do not have any demo that measures body temperature or dehydration.
Zigang
