hi,
LDC1612 is used as a rotary encoder. What is the position accuracy?
Thanks!
hi,
Thanks!
The accuracy depends on the implementation of the encoder. We have a couple different examples of rotational sensing with the LDC product line that can be referenced:
The accuracy that you get depends on the implementation method of the encoder as well as the coil and target design. If there is a desired accuracy for the application, you can keep that in mind in the design process to try to achieve it.
Justin Beigel
