IWRL1432BOOST: Setting RX Gain in mmWavestudio
Part Number: IWRL1432BOOST
Other Parts Discussed in Thread: IWRL6432BOOST, IWRL1432
Good day,
I am attempting to get the IWRL1432Boost EVM up and running using mmWave studio. I seem to be running into an issue setting the RX Gain on. This is how I currently attempt to set the gain in the GUI:
1. Change the RX Gain to the desired value.
2. Then I hit the select button.
3. Then I ensure that the RX Gain Calib box is checked.
4. Then I run the calibration by hitting the select button.
I have attempted the exact same process above using a LUA script, which does not seem to work. The above process and LUA script works with the IWRL6432Boost so I am unsure why it is not working with this platform. Any advice would be much appreciated. I am able to capture data and adjust sweep parameters, it just seems like the RX Gain is stuck at 30 dB.
