Part Number: TMCS1126
Hi team,
With OC pull up to VS, when test OC pin during power down, there is many glitch on OC pin. In below waveform, blue is VS. purple is OC pin. you can see significant glitches during power down. After zoom in the waveform, the OC seems continuously be pull down to GND. Could you pls help to check this issue and explain the reason? Thanks!
Rayna
