Hello TI Technical Support Team,
I am analyzing the Long Range People Detection project code, specifically within the GTRACK module of Radar Toolbox version 3.10.00.05.
1. Observation in trackerproc_3d.c: In the code, I found the following line which seems to statically initialize or reset the current target descriptor index:
trackerProcObj->targetDescrHandle->currentDescr = 0; /*For now, use only the ping side */
2. Concern: The comment suggests that currently only the Ping side (index 0) is being used. After reviewing the related files, I could not find any subsequent code logic that modifies or toggles the trackerProcObj->targetDescrHandle->currentDescr variable (i.e., changing it from 0 to 1 or vice versa) in a typical Ping-Pong double-buffering fashion.
My Question:
Is the static initialization to
0and the exclusive use of the Ping side (Descriptor 0) intentional in this specific project (LRPD 6843)? -
If the value is updated elsewhere in the code, could you kindly point me to the relevant function or file where the
currentDescrtoggle occurs?
I look forward to your reply. Thank you.
Best regards, [JAEHOON KIM]
