Other Parts Discussed in Thread: IWR1443BOOST, , IWR1443, MMWAVE-SDK
Hi everyone,
I'm currently experimenting with IWR1443BOOST board.
I need to modify the TIDEP-0091 source code to get high accuracy range measurement. Actually I need to modify the TIDEP-0091 source to get the accuracy of "Industrial tool box - High Accuracy Range Measurement - 14xx lab".
I understand that the power consumption may not meet the level transmitter requirements. I'm not concerned about the power consumption at the moment.
Since. the High Accuracy Range measurement lab requires the config data loaded from the PC each time, all I need is to get high accuracy range measurements without connecting to a PC.
I went through the source codes of the two projects, but I'm bit lost with understanding the order of configuration with CLI based config. of high accuracy lab.
How can I modify TIDEP-0091 source code to get high accuracy range measurements? Could someone help me with the steps I need to follow to modify the source code?
A guidance for this is highly appreciated.
Cheers,
Randy
