How to extract the x,y,z values of the detected objects in ROS ?
Please see the following E2E thread which discusses the Pointcloud2 format used by ROS to hold the detected points. Any node which accepts that format can use the data.
https://e2e.ti.com/support/sensor/mmwave_sensors/f/1023/t/675733
You can look on ROS.org for ways to save or print the ROS Pointcloud2 data. One example would be to use 'rostopic echo /mmWaveDataHdl/RScan' to print the pointcloud data to the terminal screen. You can also look at the pcl_ros commands on http://wiki.ros.org/pcl_ros to convert it or save it to a PCD file.
Please mark the thread as answered if your question is resolved or reply if more support is required.
John
