I am trying to find a quick way of testing/verifying this component meet specification. Would appreciate any information. Thank you.
Hi Cheem,
Typically, you would want to validate the accuracy in an oil bath or at the very least with a temperature oven.
You will need a high accuracy reference probe as this will determine the best accuracy you can measure.
-Kelvin
Cheem,
You will need a temperature controlled oil bath with an RTD reference probe.
Place about 10 LM34 devices on a pcb board and test them in the oil bath.
Sweep the temperature over the range of interest. Make sure to have enough soaking time at the set points (10 min is a good start).
You will also need to have a precision data acquisition system to measure the analog output of the LM34.
This way you can validate the accuracy of the LM34 without including external error sources.
-Kelvin
Cheem,
Here is another way to easily/cheaply validate the LM34 accuracy:
Use hot plate with magnetic stirrer
Use mineral/vegetable oil + beaker for your oil bath
Use TMP116EVM as an alternative reference to RTD. This is a very accurate digital temperature sensor (0.2C accurate) and you can get this EVM for $25 on ti.com. The accuracy is more than enough to validate LM34 accuracy
Keep in mind that if you don't have insulation between the beaker and air there will be a temperature gradient at the edge. So at the end of day, it might be worth it to buy an oil bath.
Let me know what you think.
-Kelvin
