I am trying to build ti mmwave sdk for 02_00_00_04 version by following mmwave_sdkk_user_guide.pdf document. And getting below error. Please help me out.
E7440:~/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/demo/xwr16xx/mmw$ make all
Configuring RTSC packages...
/home/nitin/mmwave_sdk_ti/xdctools_3_50_04_43_core/xs --xdcpath="/home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages;/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages" xdc.tools.configuro -t ti.targets.arm.elf.R4Ft -p ti.platforms.cortexR:AWR16XX:false:200 -r release -c /home/nitin/mmwave_sdk_ti/ti-cgt-arm_16.9.6.LTS -DMMWAVE_SDK_DEVICE_TYPE=xwr16xx --compileOptions "--enum_type=int" -o mss/mmw_configPkg_xwr16xx mss/mss_mmw.cfg
making package.mak (because of package.bld) ...
generating interfaces for package mmw_configPkg_xwr16xx (because package/package.xdc.inc is older than package.xdc) ...
configuring mss_mmw.xer4ft from package/cfg/mss_mmw_per4ft.cfg ...
generating custom ti.sysbios library makefile ...
Starting build of library sources ...
making /home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/demo/xwr16xx/mmw/mss/mmw_configPkg_xwr16xx/package/cfg/mss_mmw_per4ft.src/sysbios/sysbios.aer4ft ...
gmake[1]: Entering directory `/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/demo/xwr16xx/mmw/mss/mmw_configPkg_xwr16xx/package/cfg/mss_mmw_per4ft.src/sysbios'
cler4ft /home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages/ti/sysbios/BIOS.c ...
asmer4ft /home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm.asm ...
asmer4ft /home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages/ti/sysbios/family/arm/TaskSupport_asm.asm ...
asmer4ft /home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages/ti/sysbios/family/arm/v7r/vim/Hwi_asm.sv7R ...
asmer4ft /home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages/ti/sysbios/family/arm/v7r/vim/Hwi_asm_switch.sv7R ...
asmer4ft /home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages/ti/sysbios/family/arm/exc/Exception_asm.asm ...
asmer4ft /home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages/ti/sysbios/family/arm/v7r/tms570/Core_asm.sv7R ...
arer4ft BIOS.obj arm_IntrinsicsSupport_asm.obj arm_TaskSupport_asm.obj vim_Hwi_asm.obj vim_Hwi_asm_switch.obj exc_Exception_asm.obj tms570_Core_asm.obj ...
gmake[1]: Leaving directory `/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/demo/xwr16xx/mmw/mss/mmw_configPkg_xwr16xx/package/cfg/mss_mmw_per4ft.src/sysbios'
Build of libraries done.
cler4ft package/cfg/mss_mmw_per4ft.c ...
Finished configuring packages
[R4 Device/Type: awr16xx/xwr16xx] Building file: mss/mss_main.c
[R4 Device/Type: awr16xx/xwr16xx] Building file: mss/cli.c
/home/nitin/mmwave_sdk_ti/ti-cgt-arm_16.9.6.LTS/bin/armcl -mv7R4 --code_state=16 --float_support=VFPv3D16 --abi=eabi -me -g --display_error_number --diag_warning=225 --diag_wrap=off -z --reread_libs --warn_sections --rom_model --unused_section_elimination -i/home/nitin/mmwave_sdk_ti/ti-cgt-arm_16.9.6.LTS/lib --reread_libs --emit_warnings_as_errors --define=MMWAVE_L3RAM_SIZE=0xC0000 -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/osal/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/esm/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/soc/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/pinmux/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/uart/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/dma/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/crc/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/gpio/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/drivers/mailbox/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/control/mmwavelink/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/control/mmwave/lib -i/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/utils/cli/lib -llibosal_xwr16xx.aer4f -llibesm_xwr16xx.aer4f -llibsoc_xwr16xx.aer4f -llibpinmux_xwr16xx.aer4f -llibdma_xwr16xx.aer4f -llibcrc_xwr16xx.aer4f -llibuart_xwr16xx.aer4f -llibgpio_xwr16xx.aer4f -llibmailbox_xwr16xx.aer4f -llibmmwavelink_xwr16xx.aer4f -llibmmwave_xwr16xx.aer4f -llibcli_xwr16xx.aer4f \
-lmss/mmw_configPkg_xwr16xx/linker.cmd --map_file=xwr16xx_mmw_demo_mss.map obj_xwr16xx/mss_main.oer4f obj_xwr16xx/cli.oer4f \
/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/ti/platform/xwr16xx/r4f_linker.cmd mss/mss_mmw_linker.cmd -l"rtsv7R4_T_le_v3D16_eabi.lib" -o xwr16xx_mmw_demo_mss.xer4f
<Linking>
cp -f mss/mmw_configPkg_xwr16xx/package/cfg/mss_mmw_per4ft.rov.xs mss_mmw_per4ft.rov.xs
Built the MSS Millimeter Wave Demo [Preparing the BIN Format]
mono /home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages/scripts/ImageCreator/xwr16xx/out2rprc/out2rprc.exe xwr16xx_mmw_demo_mss.xer4f xwr16xx_mmw_demo_mss.bin
Parsing the input object file, xwr16xx_mmw_demo_mss.xer4f.
Appending zeros 0
Appending zeros 256
File conversion complete!
Built the MSS Millimeter Wave OUT and BIN Formats
/home/nitin/mmwave_sdk_ti/xdctools_3_50_04_43_core/xs --xdcpath="/home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages;/home/nitin/mmwave_sdk_ti/mmwave_sdk_02_00_00_04/packages" xdc.tools.configuro -t ti.targets.elf.C674 -p ti.platforms.c6x:AWR16XX:false:600 -DMMWAVE_SDK_DEVICE=awr16xx -DMMWAVE_SDK_DEVICE_TYPE=xwr16xx -r release -c /home/nitin/mmwave_sdk_ti/ti-cgt-c6000_8.1.3 -o dss/mmw_configPkg_xwr16xx dss/dss_mmw.cfg
js: "/home/nitin/mmwave_sdk_ti/bios_6_53_02_00/packages/ti/targets/ITarget.xs", line 213: Error: template generation of 'compiler.opt' failed: Error: /home/nitin/mmwave_sdk_ti/ti-cgt-c6000_8.1.3 cannot be found. Ensure that rootDir for the C674 target is set correctly in ./config.bld
"./package.bld", line 55
gmake: *** Deleting file `package.mak'
gmake: *** No rule to make target `.configuro'. Stop.
js: "/home/nitin/mmwave_sdk_ti/xdctools_3_50_04_43_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
make: *** [dssDemoRTSC] Error 1
Nitin
