AWR1642BOOST: How can I config chirp configuration to enable tx1/tx2 send one by one in mmWave Studio? my mmWave Studio is 2.0.0.2
Part Number: AWR1642BOOST
1、I have read this article《How can I config chirp configuration to enable tx1/tx2 send one by one in mmWave Studio?  》,but I can"t find where is the chirpCfjindex[].If there is a screenshot, it will be very easy to understand.
2、I find that I set "1Tx 4Rx  128chirps 256samples 1 Frame "the adc_data.bin size is 256kb . I set  "2Tx 4Rx  128chirps 256samples 1 Frame " the adc_data.bin size is the same 256kb. but I think "2TX" should be twice as big as "1TX". Is my where configuration appeared a problem?
Thank you very much for your answer and  look forward to your discussion!
  • ShaoHui,
    Make sure that you enable the channels that you want to use in the StaticConfig Tab and continue with normal set up:
    When you get to the SensorConfig Tab,
    1. Profile : Set the profile that you are going to use for the first chirp
    2. Chirp: enable the TX channel for that profile and set, in this case the 1st TX (TX0)
    for the second chirp:
    1. Chirp: we will use the same Profile Id,
    2. Chirp: change the start and end Chirp for Cfg  to 1,
    3. Chirp: then  choose the 2nd Tx (TX1)
    finally in the Frame section:
    1. change the Start Chirp TX to 0; this is the 1st TX
    2. change the End Chirp TX to 1; this is the 2nd TX
    3. set and collect data as usual
    Hope this helps
    Alex
