Other Parts Discussed in Thread: LDC1101
Hi, I purchsed LDC1000 EVM. And I have a one question.
I'm not good at English. So I have difficulty in understanding datasheets.
As I understand, LDC1000 EVM requires the maximum, minimum of Rp.
And there's a guide that describe the method how to measure the Rp with other Analyzers.
But, I think it's enough that using only LDC1000 EVM.
if I insert wide range Rp max, min value and move the conductor at the desired distance, than the graph will show the Rp value.
And I can use the graph's result. I can insert Rp max, min value that showed in previous graph.
So, I wonder this method is suitable. and if not suitable, why? and if it's suitable, why the method that using Analyzer is mentioned? Is it more accurate?
Thank you.
