Other Parts Discussed in Thread: LMT86
Dear TI Support team,
I have a question regarding the RC sensor output filter selection.
In the datasheet, there is the Table 4 with the recommended series resistors values.
Could you please check it and explain what is the reason of choice of such values.
The table seems not logical for me: for the higher values of the output capacitance - the lower value of the series resistor is recommended to use!
For me, it should be vice versa: to allow output amplifier stage to drive the higher output capacitance, the higher resistance value should be used - "stronger isolation" between the output an output capacitance is needed.
Isn't it the error in the datasheet?
Thanks!
Igor
