LM75A: Absolute rating of Tj max
Part Number: LM75A
Other Parts Discussed in Thread: TMP117, TMP116
Hi Team,
There is a question of LM75A. In the datasheet, recommended operating conditions of TJ temp range is -55C~125C.
What's the absolute maximum ratings of Tj Max?  Can we support Tj max up to 150C?
Thank you.
  • Hi Lilian,
    No variant of 75 can report a temperature above 127C. The way the data is encoded in 8 bits won't allow it.
    Further, I can't make any promises beyond the datasheet specifications.
    Here's a list of I2C temperature sensors with 150C operating range. The TMP116 also supports 150C operation, but accuracy is not guaranteed above 125C. TMP116 is a lower cost version of our flagship sensor TMP117.
    https://www.ti.com/sensors/temperature-sensors/digital/products.html#p1192=0;150
    thanks,
    ren
  • Hi Ren,
    Thanks for your reply, I understand that LM75 can't work at temp over 127.  But my customer's question is if the LM75 Tj junction temp can accept 125~150C but device will not be damaged?  they don't need LM75 working at 125~150.
    In the datasheet, our recommended operation rating of Ta range is -55~125. For my understanding, when the Ta=125C, Tj will be 150C around?  right?
    Thank you.
  • Hi Lilian,
    For temperature sensor, we expect Ta=Tj. The sensor does not consume significant power to raise it's internal temperature. If it did, it would not be a very good sensor.
    thanks,
    ren
