Other Parts Discussed in Thread: TMAG5111, TMAG5110
When can I expect to order samples TMAG5170A2 and TMAG5111?
Alexander,
Thank you for reaching out. Currently both devices are preview only and only available for comparison within their respective datasheets. The exact sample dates for these devices is not information I am able to release, however.
The TMAG5170A1 is currently visible on TI.com for an advance product visibility. The significant difference between A1 and A2 is the sensitivity range. You should be able to acquire samples and the EVM with an A1 device for preliminary testing. I do understand this means you may require a different magnet than what is currently in your system. If you are willing to share details of your setup, we could help you review the magnet in your application to see what flexibility you might have here.
TMAG5111 is currently visible as preview only in association to the TMAG5110 datasheet. The key difference between the devices being that TMAG5111 outputs are formatted for speed and direction. TMAG5110B2 is currently available for order as well if you would like to perform preliminary evaluations with your magnet.
Let me know if you need any further guidance or help for your design.
Scott
