I am trying to use 1MHz transducer with TDC1000-GASEVM.
Since the resonance frequency has changed way above 58KHz~300KHz, I believe I have to change the input configuration from below circuit
Since the application is for water flow(in non intrusive way), with 1MHz, I will have to use capacitive feedback for LNA. How can I adjust from above circuit for my application?(By the way, I need higher voltage because signal attenuates significantly when changing layers of pipe, liquid and wedge)
