I am testing HDC1080 and found that there is some offset regarding humidity measurement.
Before testing HDC1080, I was using HDC1000 for my board.
HDC1000 showed about 15% offset and found some complaint on E2E.
And TI recommended using HDC1080. But HDC1080 showed the similar offset as HDC1000.
I am a little upset with the offset. What am I wrong with my board?
Could you recommend the other chip for humid/temp?
What is the conversion time for humidity and temperature at the same time?
I am using the default resolution.
I find 8ms is used in your code. But on E2E TI is referring to 40ms.
Could you recommend the time for conversion?
Also I am concerned about my code.
I am using CC1310 for wireless MCU and code based on TIDA-00488.
TIDA-00488 is based on HDC1000. I think there is no code difference between HDC1000 and HDC1080.
I am sorry for too easy question. I need double check.
Thanks in advance.
Baeyoung
