The datasheet for the LM26NV www.ti.com/.../lm26nv.pdf says that the part is factory programmable for any temperature from -55C to 110C in 1 degree C increments. It also says that you can specify one of several outputs. This is all specified using the last 3 letters of the part number.
I need the following part numbers:
- LM26CIM5-hnh (4 deg C / push pull / US)
- LM26CIM5-hth (8 deg C / push pull / US)
Questions:
- Can order the above parts with the numbers I have derived from the tables in the datasheet on page 4 of: www.ti.com/.../lm26nv.pdf
- Can I get samples of these?
- How do I get samples? I can't figure it out on the TI website and customer support has no idea.
