Part Number: IWR1443BOOST
Other Parts Discussed in Thread: IWR1443
I started a week ago with the IWR1443 to read the data out, I am able to do this and the get everything read out as it should. My only question about the data is from the objects that is being send. I want to know what some of the data means.
When you get the data package of the objects you get multiple values I know some of them what they are if you could help me figure out the rest and please correct me if I got anything wrong.
Rangeindex - this is the distance in meters.
dopplerindex - this is the speed in m/s
peakvalue - I thought this was the dB from the object as is shown in the range profile plot on the mmwave visualizer.
X - Is this the distance in m or the angle?
Y - this is the same as the range, so the dinstance of the object.
Z - is this also in m or just the angle?
So my second question is about the gesture demo is there a document that explains the code and what is does? I read through the code multiple times but have a hard time figuring out what all the data means also how to you determine if the gesture is a swipe or a twirl?
