TIDEP-0090: IWR1642BOOST interface to other controller
Part Number: TIDEP-0090
Other Parts Discussed in Thread: IWR1642BOOST, IWR1642
Hi to all,
I have a query regarding. Is possible to interface IWR1642BOOST(EVB) with other controller. If it yes what is the peripheral and data format?
Any answers, it would be appreciated.
Muralidhar M
  • Former Member
    0 Former Member
    Please refer to table 3.1 of the datasheet for the available peripherals for the IWR1642
    Amanda
  • Dear Sir,
    Thanks for your response..
    That's ok for IWR1642 IC but we need IWR1642 EVB interfacing to other controller. output data format of also needed.
    Muralidhar M
  • Former Member
    0 Former Member in reply to TEMC
    Please refer to the Users Guide of the IWR1642 for Connecting the BoosterPack to the LaunchPad or the MMWAVE-DEVPACK
    www.ti.com/.../swru521a.pdf
    The reference design also gives an example of LaunchPad use with the Boost EVM: www.ti.com/.../tidud26a.pdf
    The output data format will be dependent on the software you are using, please refer to the documentation of the software.
    Amanda
  • thanks for the response...
    Is there any possibility to get data without DEVPACK.
    regards,
    Muralidhar M
  • Former Member
    Can you please describe your application or use case and what data you are looking to get?
    The IWR1642Boost can of course be used in stand alone mode to acquire data which is delivered via UART as described in the Traffic Monitoring TI Design www.ti.com/.../TIDEP-0090
    Amanda
    We want to interface IWR162BOOST kit to our controller, for that we need info about how to configure the radar and what type of data we get (data format)?. is it SPI, UART, I2C which type of interface is available to interface our controller?
    Thanks for your support,
    regards,
    Muralidhar M
  • Former Member
    Please refer to the data sheet which lists the interfaces available on the IWR1642BOOST (UART, SPI, I2C). The type of data and data format will depend on the code you choose to deploy on the target/device. Please refer to the documentation of the software for data format.
    Amanda
