IWR1642BOOST: The output data from IWR1642BOOST running mmWave demo visualizer
Guru 16800 points
Part Number: IWR1642BOOST
Could you tell me about the detail output data from IWR1642BOOST running mmWave demo visualizer?
We want to know the format of the output data and consider using the data in another application.
Nomo
  • Hi Nomo,
     To process the data from DataPort(UART): See the Visualizer User's Guide, section 4.4, to understand what the data contains. Information on the actual data is available in the doxygen - <mmWave_SDK_Install_DIR>\packages\ti\demo\xwr16xx\mmw\docs\doxygen\html\index.html.
    User's Guide: www.ti.com/.../swru529a.pdf
     There is a demo in beta that saves the recorded object point cloud data to a human readable CSV file - you can read the code and understand the data conversion process:
    mmWave visualizer with the LOG function: dev.ti.com/.../
    Data format description of UART data for mmWave Demo.
    • SDK01.00.00.05: e2e.ti.com/.../mmw-Demo-Data-Structure_5F00_8_5F00_16.pdf
    • SDK01.01.00.02: Section "Output information sent to host" file:///C:/ti/mmwave_sdk_01_01_00_02/packages/ti/demo/xwr16xx/mmw/docs/doxygen/html/index.html
    • SDK01.02.00.05: Section "Output information sent to host" file:///C:/ti/mmwave_sdk_01_02_00_05/packages/ti/demo/xwr16xx/mmw/docs/doxygen/html/index.html
    • SDK02.00.00.04: Section "Output information sent to host" file:///C:/ti/mmwave_sdk_02_00_00_04/packages/ti/demo/xwr16xx/mmw/docs/doxygen/html/index.html
    Wesley
  • Wesley-san,
    Thank you for your reply.
    I'll check the information from you.
    If I have additional questions, I'll post another thread.
    Nomo
