Part Number: IWR1443BOOST
Other Parts Discussed in Thread: IWR1443, IWR1642BOOST
Tool/software: Linux
I've been trying to upload different chirp configurations to the IWR1443 mmWave sensor and plot the resulting Point Cloud using ROS. The already given example runs perfectly. However, I've tried to run it giving as an input a different .cfg (instead of 1443_2d/3d.cfg) file and I doesn't work (I've taken the .cfg files from the TI mmWave chirp database). In general, tends to give different errors while sending the configuration parameters to the sensor - and specially with the last "sensorStart" of the .cfg file-. Is there any limitation in terms of what chirp configurations can work jointly with ROS or anything I consider when trying to use different .cfg files?
Thanks!
