Part Number: TDC7200EVM
Hi Experts,
Thank you very much for supporting.
We are checking the contents below.
And we would like to obtain the TOF data somehow.
Please help.
CCS project: TCD700EVM_USB
File: host_interface.h
We were able to send a command 0x0A successfully by Terminal SW.
#define Command_LED_Toggle 0x0A // Toggle LED
// PacketBuffer[0],[1] Command
Moving forward, we would like to get the TOF data by using the
#define Command_Start_TOF_One_Shot 5 //Start TOF command
// PacketBuffer[2],[3] Expected num of stop pulses
// PacketBuffer[8] Response: start-stop1 data low byte
// PacketBuffer[9] Response: start-stop1 data high byte
// PacketBuffer[10] Response: start-stop2 data low byte (only if numstop >= 2)
// PacketBuffer[11] Response: start-stop2 data high byte
// PacketBuffer[12] Response: start-stop3 data low byte (only if numch == 3)
// PacketBuffer[13] Response: start-stop3 data high byte
We do not know how to configure the necessary parameters to get the one shot TOF data from the EVM by sending Command_Start_TOF_One_Shot.
Could you please teach us how to set correctly to get the data?
Thank you very much in advance for your kind support.
Hitoshi
