CCS: Fail to import AWR1843 project to CCS
Other Parts Discussed in Thread: AWR1843, TIGER
Hi
We would try SDK3.1 arch on AWR1843 but we meet the problem when importing xwr18xx project.
Please help with this problem, thanks
I tried to do below steps to import demo project "xwr18xx"
File ->  Import -> Code Composer Studio -> CCS Projects -> Select search-directory  "C:\TI\mmwave_sdk_03_01_00_02\packages\ti\demo\xwr18xx\mmw" -> Finish
but I got below error message.
"Import failed for project 'mmw' because its meta-data cannot be interpreted. Please contact support."
Dev. Environment :
mmWave SDK version : mmwave_sdk_03_01_00_02
Code Composer Studio version : 8.2.0.00007
Tiger
    This will not work as there is no CCS project to import in the SDK directory you mentioned.
    As mentioned in the other post that you linked to, CCS projects are typically included in the Industrial Toolbox, not the SDK. The Industrial Toolbox can be downloaded from TI Resource Explorer, and demo projects can then be imported directly from Resource Explorer also.
    However, I do not see any labs/example projects for AWR1843 yet in the Industrial Toolbox. But you can follow the procedure in the MMWave SDK User Guide (found in the SDK /docs directory) for loading and running demos.
    I will forward this thread to the mmWave experts so they can provide additional comments or details regarding CCS projects/labs for AWR1843.
  • Thanks for your information.
    Just because we can't find AWR1843 on the Toolbox, so that we try to use the AWR1843 sample code of SDK.
    Could you share the available source of AWR1843 for CCS?  Thanks a lot.
  • https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/1023/demo0005_5F00_mmwave_5F00_sdk_5F00_18xx_5F00_pjt.7z
  • Could you provide the password of demo0005_mmwave_sdk_18xx_pjt.7z
    Thank a lot.
  • The file is protected by a password. Please share the password. Thanks a lot.
  • Password is 123456
    Thank you
    Cesar
