Dear Support,
I'm working with the temperature sensor "TMP275". We use the ALERT Pin for toggle a device on or off by reaching a negative temperature value in T(high). After the device reach the T(low) value it turn on and we make a default configuration for the sensor to read default temperature. In this state we change polarity so the failure occurs, that the device shut down once more. The question is now:
When will be the ALERT configuration enable? If i change the default configuration sequence from:
write configuration
write T(high)
write T(low)
to:
write T(high)
write T(low)
write configuration
it seems to be working..
Hope you can help me!
Best regards
Lukas
