LM94022-Q1: if LM94022-Q1 is close 3.2kV.
Expert 2030 points
Part Number: LM94022-Q1
Dear Sir,
My customer develop ionizer for automotive.
my customer consider PCB layout as below picture. Ionizer have to generate 3.2KV and close to LM94022. the length between Ionizer and LM94022 is 10mm~15mm.
LM94022 have any effect?
  • Hi Dexter,
    I will look into this and get back with you.
    Jalen
  • In reply to Jalen Tate89:
    Dexter,
    Can you provide more information here on the end equipment/use case? i.e what a 3.2kV ionizer in a car is used for? It is hard to infer much from the diagram given.
    Generally, it is hard to tell the effect the ionizer could have on our temperature sensor, the 3.2kV would be a concern as it could cause noise to couple into our part.
    Jalen
    Dear Jalen,
    Thank you for your prompt reply.
    I will check more information about 3.2kV ionizer and let you know that.
  • In reply to Dexter Choi60:
    Dexter,
    Look foward to hearing back.
    Jalen
    Hi Dexter,
    Following up here. Do you have any more information?
    Jalen
