I located the VAC (current sensor) close to relay (~0.3cm) and I have constant magnetic field effect on the VAC when I close the relay.
I tried to connect the DEMAG pin to manual switch and do demagnetization after the relay has closed, but it doesn't help.
the "easy" solution is to change my PCB design, can I solve it without to change the design?
thanks for your replay.
