Other Parts Discussed in Thread: AWR1642
Hi together,
I need some clarification regarding windowing in the mmWave Demo v. 3.2.
According to the RangeProcDSP Doxygen, digitized IF raw data is 1D-Range-FFT processed without mentioning any windowing. Then, according to the Doppler DPU Doxygen, "input samples are multiplied by a window function" before performing the 2D-Doppler-FFT. Furthermore, it says that the window size and coefficients are defined in DPU_DopplerProcHWA_HwaCfg_t. However in the program code, there is no such struct instantiated.
Even more confusing, the object_detection_data_scaling.xlsx excel sheet in \ti\mmwave_sdk_03_02_00_04\packages\ti\datapath\dpc\objectdetection\common\docs states that data is tapered with a Blackman window before the 1D-FFT and Hann windowed before the 2D-FFT.
So what I want to know: Is data anywhere in the Demo processing chain windowed? If yes, which window is used? And where is this action to be found? As the Doppler DPU Doxygen says, "Window coefficients must be provided by application".
Best regards
