Hi Team,
My customer would like to know if the DAT file contains the detailed magnitude and phase information of each Rx antenna of IWR1642BOOST? If the answer is yes, then how can I read this DAT file in Matlab?
_Renan
Hi Team,
_Renan
Hi Akash,
Thank you for your reply.
The *.dat file I was referring to is the one that is recorded through the use of MMWave Demo Visualizer. That does this file contains the detailed magnitude and phase information of each Rx antenna? If the answer is yes, then how can I read this *.dAT file using Matlab?
-Renan
Hello Renan,
You could review below application note i.e. "Mmwave Radar Device ADC Raw Data Capture".
http://www.ti.com/lit/an/swra581b/swra581b.pdf
This application note also has the sample matlab files to read and interpret the data.
Thanks and regards,
CHETHAN KUMAR Y.B.
Hi Chetan,
I already provided this application note to the customer however, she wanted to know if this file contains the detailed magnitude and phase information of each Rx antenna?
Renan
Renan,
Visualizer *.dat contains processed data, It does not contain raw ADC data from each Rx.
It records the UART byte stream exactly as it comes in. Therefore the data contained depends on which plots the user has enabled. All of them are processed data.
If you would like to capture detailed magnitude and phase information of each Rx antenna you need to use the DCA1000 board interface with the IWR1642BOOST board.
Thanks and regards,
CHETHAN KUMAR Y.B.
