Hi Team,
My customer need a temperature sensor with requirements below:
1. Dual in-line package;
2. ±0.5% accuracy
3. Single source
4. Can senor negative temperature
Do you have some recommendation?
Thank you
Hi Team,
2. ±0.5% accuracy
3. Single source
Thank you
Dear Xing-
I think the only through hole packages we offer for the temp sensors is TO-92 and TO-46 (which is a can package with three legs, similar to TO-92)
We normally specify our temperature accuracy by degrees C, not percentage, and all of can sense temperatures below 0.
If you could by chance ask a few more questions about the package, the range requirement of the sensor, supply voltage and interface, then use the parametric search capability found here: http://www.ti.com/sensors/temperature-sensors/products.html , I think you will be successful in narrowing down the parts we have that fit what is needed.
