Regarding to Gain and Offset on FDC2114, my customer is asking some question.
(Question)
(1) According to datasheet page 18, gain example is described following.
“If the conversion result for a channel is 0x07A3, with OUTPUT_GAIN=0x0, the reported output code is
0x07A. If OUTPUT_GAIN is set to 0x3 in the same condition, then the reported output code is 0x7A3. The
original 4 MSBs (0x0) are no longer accessible.”
When OUTPUT_GAIN is 0x0, 0 bits is shifted. But on above description , the reported output code is 0x07A and it is 4 bits right shifted.
(The same goes for OUTPUT_GAIN= 0x3.).
I couldn't make it clear about Conversion Data Output Gain.
Could you please tell me about conversion data of Output Gain and purpose of this feature more detail?
(2) According to datasheet page 19, offset is described following.
“An offset value may be subtracted from each DATA value to compensate for a frequency offset or maximize the dynamic range of the sample data."
I couldn't make it clear about it.
Could you please tell me about purpose of this feature more detail?
Tao_2199
