[FAQ] HDC2080/HDC2010 - Does TI have a list of chemicals that could affect RH accuracy when the sensors are exposed to them?
  • The following chemicals are known to cause drift of the humidity output readings which may be irreversible.
    (This list is also found in: Humidity Sensor: Storage and Handling Guidelines)
    1. Solvents such as: Toluene: C7H8, Acetone: (CH3)2CO, Ethanol: C2H6O, Methanol: CH3OH – Isopropyl Alcohol: C3H8O – Di-isopropyl Ether: C6H14O – Ethylene Glycol: (CH2OH)2 – Ethyl Acetate: C4H8O2 – Butyl Acetate: C6H12O2 – Methyl Ethyl Ketone: CH3C(O)CH2CH3
    2. Acids such as: Hydrochloric acid: HCl, Sulphuric acid: H2SO4, Nitric Acid: HNO3
    3. Other Chemicals, including: Ketenes, Ammonia: NH3, Hydrogen Peroxide: H2O2, Ozone: O3 – Formaldehyde: CH2O
    This list is not exhaustive; other, unlisted chemicals may also cause shifting of the sensing element.
