  • Resolved
[FAQ] TMP61/TMP63/TMP64 – Where can I find the Resistance-Temperature (R-T) tables for TMP61,TMP63,TMP64 thermistors and how do I use them?
Expert 6390 points
  • All of the R-T tables as well as example code for the most accurate temperature conversion methods can be found in the Thermistor Design Tool. Due to the nature of silicon, the resistance-to-temperature characteristic of TI thermistors is affected by the current passing through the device. Therefore, the resistance values of TI thermistors vary with package and bias voltage, so be sure to select the correct device and input your system parameters onto the tool.
