I have tried a circuit with a LM35DZ supplied with 24 volts, but the temperature does not seem to be working right. I can heat up the sensor and get very minimal change in the Vout pin. Tried a 10 volt power supply and getting the same results. Do i just have a bad sensor, or is the supply voltage too high and damaged it. I seen on the data sheet Max Voltage is 30vdc, but in one of the pictures it shows 4 - 20vdc
