AWR2243: Queries about programmable filter
Part Number: AWR2243
HI,
Please let me know about programmable filter newly supported in mmWave DFP 02.01.05.03 release.
(1)    Is it a HW filter or SW algorithm?
(2)    Is it mentioned in AWR2243 datasheet?
(3)    Please let me know more details about the filter design (how many orders, Decimation factor, etc)
 Thanks & Regards,
-Shibata
  • Hello Shibata,
    Do you mean the programmable filter coefficient mentioned in the ICD?
    That is a filter in digital. You can find details in the ICD, refer to the following API-   "AWR_PROG_FILT_CONF_SET_SB"
    Vivek
  • Hi Vivek,
    I’m referring “mmWave-Radar-Interface-Control.pdf”, I assume ICD stands for this document.
    Please let me know if I am wrong.
    It is still unclear, in the description for AWR_PROG_FILT_CONF_SET_SB, what “external programmable filter” means?
    Isn’t it a part of Radar Subsystem?
    Where does it located in the functional blocks of AWR devices?
    I would like to know exactly what it is, it is LPF or HPF, what is the purpose of this filter.
    Thanks & Regards,
    -Shibata
  • Hello Shibata,
    The programmable filter is part of the digital front end filter chain. It is a LPF filter. There is a default digital that is available in the digital. But if the user wants to bypass the default filter chain and have his own filter coeffients , they can set it using the "AWR_PROG_FILT_COEFF_RAM_SET_SB" API.
    regards,
    Vivek
  • Hi Vivek,
    Thanks for the clarification.
    -Shibata
