Other Parts Discussed in Thread: MMWAVEICBOOST
Hello everyone,
I recorded a data file from IWR6843ISK-ODS containing both rangeAzimuthHeatMap and rangeDopplerHeatMap. I attached both the data file and the first frame of rangeAzimuthHeatMap for the first column.
The first frame of rangeAzimuthHeatMap is a complex matrix with 12 columns, i.e. the number of virtual antennas (3x4), and 256 rows, i.e. the number of range bins.
Before starting with the AoA computation I would make a first simple test by plotting just one column that I think is the range detected by one virtual antenna. Therefore, I expected to see something similar to a range FFT output but this is not the case. Thereafter, maybe I do not understand what is the rangeAzimuthHeatMap output of the device. Please can you clarify this aspect?
Sincerely,
Emanuele
xWR68xx_AOP_processed_stream_2020_07_30T06_12_59_395.dat
1.0e+04 * 0.0555 + 6.5197i 6.3578 + 0.0669i 0.1690 + 6.4562i 0.0179 + 0.1182i 6.4993 + 6.4703i 0.0129 + 0.0252i 6.5482 + 6.5490i 0.0010 + 0.0020i 6.5531 + 6.5523i 0.0004 + 0.0003i 6.5527 + 0.0001i 0.0007 + 6.5533i 6.5534 + 0.0006i 6.5532 + 6.5531i 0.0025 + 6.5535i 6.5466 + 6.5507i 0.0068 + 0.0073i 6.5511 + 6.5480i 0.0012 + 0.0021i 6.5525 + 6.5527i 0.0004 + 0.0001i 6.5535 + 6.5534i 6.5528 + 0.0002i 0.0007 + 0.0006i 0.0003 + 0.0008i 0.0008 + 6.5502i 6.5482 + 0.0019i 0.0091 + 6.5532i 6.5466 + 0.0014i 0.0015 + 6.5527i 0.0012 + 0.0000i 6.5520 + 0.0001i 0.0014 + 6.5530i 6.5530 + 0.0014i 0.0000 + 6.5523i 6.5533 + 0.0004i 0.0009 + 0.0006i 6.5529 + 6.5529i 6.5525 + 0.0000i 0.0027 + 0.0004i 6.5513 + 6.5533i 0.0018 + 6.5525i 6.5534 + 0.0077i 6.5520 + 6.5375i 6.5441 + 0.0222i 0.0210 + 6.5334i 6.5420 + 0.0076i 0.0007 + 0.0006i 0.0002 + 6.5535i 6.5497 + 0.0052i 0.0228 + 6.5299i 6.5163 + 0.0320i 0.0240 + 6.5378i 6.5473 + 0.0000i 0.0008 + 0.0035i 0.0017 + 6.5503i 6.5471 + 0.0041i 0.0095 + 6.5504i 6.5483 + 0.0001i 6.5498 + 0.0029i 0.0081 + 6.5519i 6.5516 + 6.5519i 6.5474 + 0.0035i 0.0098 + 6.5464i 6.5432 + 0.0145i 0.0048 + 6.5340i 0.0084 + 0.0160i 6.5360 + 0.0053i 0.0216 + 6.5237i 6.5382 + 0.0264i 0.0002 + 6.5445i 0.0042 + 0.0021i 6.5522 + 6.5522i 0.0019 + 0.0017i 6.5509 + 6.5530i 0.0011 + 6.5520i 0.0001 + 0.0008i 0.0008 + 0.0040i 6.5486 + 6.5466i 0.0080 + 0.0067i 6.5497 + 6.5492i 0.0002 + 0.0000i 6.5528 + 0.0014i 0.0010 + 6.5530i 6.5535 + 0.0021i 6.5525 + 6.5500i 0.0024 + 0.0031i 6.5503 + 6.5518i 0.0034 + 0.0004i 6.5515 + 0.0005i 6.5534 + 6.5525i 0.0008 + 0.0007i 0.0003 + 6.5534i 6.5528 + 0.0007i 0.0007 + 6.5531i 6.5528 + 6.5528i 0.0006 + 0.0008i 6.5530 + 0.0000i 0.0003 + 6.5535i 0.0008 + 6.5533i 6.5521 + 0.0003i 0.0014 + 0.0004i 6.5520 + 6.5526i 0.0020 + 0.0007i 6.5517 + 6.5533i 0.0013 + 0.0005i 6.5527 + 6.5533i 0.0005 + 6.5532i 0.0005 + 0.0015i 6.5526 + 6.5510i 0.0009 + 0.0025i 6.5530 + 6.5526i 6.5519 + 6.5532i 0.0037 + 0.0010i 6.5511 + 6.5532i 0.0008 + 6.5528i 6.5533 + 0.0009i 0.0004 + 6.5535i 6.5532 + 6.5532i 0.0002 + 0.0005i 6.5532 + 6.5530i 0.0003 + 0.0005i 0.0006 + 6.5531i 6.5530 + 0.0004i 0.0001 + 6.5531i 0.0000 + 0.0001i 0.0001 + 0.0006i 6.5530 + 6.5521i 0.0011 + 0.0022i 6.5527 + 6.5519i 0.0009 + 0.0009i 6.5530 + 6.5527i 6.5532 + 0.0011i 0.0013 + 6.5523i 6.5521 + 0.0009i 0.0004 + 0.0000i 0.0011 + 0.0001i 6.5523 + 6.5531i 0.0007 + 0.0001i 6.5532 + 6.5535i 0.0001 + 0.0005i 0.0000 + 6.5530i 0.0002 + 0.0002i 6.5533 + 6.5535i 0.0000 + 0.0002i 0.0001 + 6.5534i 0.0000 + 0.0001i 0.0001 + 6.5535i 6.5534 + 6.5535i 0.0001 + 0.0003i 6.5535 + 6.5534i 0.0002 + 0.0002i 6.5535 + 6.5530i 0.0002 + 0.0005i 6.5533 + 0.0001i 0.0003 + 6.5531i 6.5534 + 0.0006i 0.0001 + 6.5531i 0.0001 + 0.0004i 6.5532 + 6.5534i 0.0007 + 6.5535i 6.5528 + 0.0005i 0.0005 + 6.5529i 6.5535 + 0.0007i 0.0002 + 6.5532i 6.5532 + 0.0002i 0.0001 + 6.5535i 0.0001 + 0.0001i 0.0001 + 6.5532i 6.5527 + 0.0005i 0.0020 + 6.5534i 6.5512 + 0.0000i 0.0013 + 6.5534i 6.5531 + 0.0001i 0.0005 + 6.5534i 6.5530 + 0.0003i 0.0000 + 6.5534i 6.5534 + 6.5533i 0.0015 + 0.0001i 6.5511 + 0.0012i 0.0019 + 6.5519i 6.5529 + 0.0009i 0.0002 + 6.5532i 0.0000 + 0.0002i 6.5535 + 6.5535i 0.0001 + 0.0000i 6.5534 + 0.0000i 0.0004 + 0.0002i 6.5534 + 0.0000i 0.0000 + 6.5535i 0.0002 + 0.0000i 6.5534 + 0.0003i 0.0000 + 6.5532i 0.0004 + 0.0002i 6.5531 + 6.5535i 0.0003 + 0.0001i 6.5534 + 0.0000i 0.0001 + 6.5535i 0.0000 + 0.0000i 6.5535 + 0.0000i 0.0002 + 0.0000i 6.5534 + 6.5535i 0.0001 + 0.0001i 0.0001 + 0.0001i 6.5534 + 0.0000i 0.0001 + 6.5535i 0.0001 + 0.0002i 6.5535 + 6.5533i 0.0000 + 0.0001i 0.0000 + 0.0001i 0.0001 + 6.5533i 6.5535 + 0.0001i 0.0001 + 0.0001i 0.0000 + 6.5534i 6.5535 + 0.0002i 0.0002 + 6.5534i 6.5534 + 0.0001i 0.0002 + 0.0000i 6.5534 + 6.5535i 0.0001 + 0.0001i 6.5535 + 0.0000i 0.0001 + 0.0000i 6.5535 + 0.0000i 0.0001 + 0.0000i 0.0000 + 6.5535i 6.5534 + 0.0000i 0.0002 + 0.0000i 6.5534 + 6.5535i 0.0002 + 0.0000i 6.5535 + 6.5535i 0.0000 + 0.0002i 0.0001 + 6.5534i 0.0000 + 0.0000i 0.0000 + 0.0000i 0.0000 + 0.0000i 0.0000 + 6.5535i 0.0000 + 0.0000i 0.0000 + 0.0000i 0.0000 + 0.0000i 0.0001 + 0.0000i 6.5534 + 6.5535i 0.0001 + 0.0001i 0.0000 + 6.5535i 0.0000 + 0.0000i 0.0001 + 0.0000i 0.0000 + 0.0000i 0.0000 + 0.0000i 0.0000 + 0.0000i 0.0001 + 6.5535i 0.0000 + 6.5535i 0.0001 + 0.0000i 6.5534 + 6.5534i 0.0012 + 0.0006i 6.5518 + 0.0001i 0.0008 + 6.5500i 6.5534 + 0.0115i
