Part Number: TMP102-Q1
Hi there,
In TMP102-Q1 datasheet Page 14 Figure 10: "Frame 3 Two-Wire Slave Address Byte". Should this Frame be removed? Frame1 has Slave Address Byte. "Read Register" Byte should just following "Pointer Register" Byte, Correct?
In this Figure 10, Read Format is: Slave Address Byte--Point Register Byte--Slave Address Byte--Read Register Byte.
Should this be changed as : Slave Address Byte--Point Register Byte--Read Register Byte ?
Thank you.
Ling Shen
Ling Shen,
I will take a look and respond to you by Monday end of business.
Jalen
In reply to Jalen Tate89:
Frame 3 should not be removed. This is the proper protocol for read operation.
The proper Read Format is: Slave Address Byte--Point Register Byte--Slave Address Byte--Read Register Byte as indicated.
Please refer to sections 7.3.5 and 7.3.6 for more details.
