in one of the threat was mentioned that this document Antenna Design Guide for 60GHz Radar_v0.3.docx would be released Q3 2019. But I still can not find it.
Can you tell me where I can find it or can you send it please?
Hello
While we help you get the document information.
Have you had a chance to look at the following collateral which is a bit more generic for Hardware/RF design considerations.
TI mmWave Radar sensor RF PCB Design, Manufacturing and Validation Guide
Thank you,
Vaibhav
Hello
Yes got it but I did not find the dimensions for the sqared ares and so on. I thought ( hoped) that this will be in more detail in the other document.
Markus,
For the IWR6843 we have two Antenna designs, IWR6843ISK (High gain antenna) and IWR6843ISK-ODS (Wide field of view antenna).
You may want to review TI mmWave resource explorer for Antenna database.
https://dev.ti.com/tirex/explore/node?node=ANS49gohN4gX2.NvHAAGGQ__VLyFKFf__LATEST (IWR6843-ISK)
https://dev.ti.com/tirex/explore/node?node=AEHINipfikce5tr4bK3rtg__VLyFKFf__LATEST (IWR6843 ISK-ODS)
In the IWR6843ISK and IWR6843ISK-ODS folder PCB design package is provided, it has all the antenna dimensions in the design package itself.
Thanks and regards,
CHETHAN KUMAR Y.B.
if I use this link
I only get an error message that the package is not there.
Markus,
Sorry, You could use the below links:
IWR6843ISK https://www.ti.com/tool/IWR6843ISK
IWR6843ISK-ODS https://www.ti.com/tool/IWR6843ISK-ODS
Thanks and regards,
CHETHAN KUMAR Y.B.
i am not clever enough to find the document with the dimensions of the antenna. If I use your link above there are lot of documents but none shows the dimensions in my opinion. But how I said maybe I am not clever enough.
Antenna is part of the Altium design package, You could download the altium viewer and load the design package to see the Antenna details in the PCB layout.
You could load the design package for IWR6843ISK from the https://www.ti.com/lit/zip/swrc355 (You could review inside IWR6843_ISK design files it contains assembly package, Design database, Fabrication package and PCB layer plots) and for the IWR6843ISK-ODS package https://www.ti.com/lit/zip/swrr165
Below link is for altium free viewer.
https://www.altium.com/altium-designer-viewer
Thanks and regards,
CHETHAN KUMAR Y.B.
thank you very much I didn´t download altium files because we don´t use that program. Know I will download the viewer and hopefully will find the dimensions.
Thank you.
Hello Markus,
Understood. Thank you for your quick confirmation.
Thanks and regards,
CHETHAN KUMAR Y.B.
