Hi TI,
Does the light sensor have a recommended range of effective transmission?
Is there a minimum requirement of that?
Thank you!
Scott
Hi TI,
Thank you!
Scott
Hi Scott,
Are you asking about transmission of a dark cover glass?
Alex
Hi Scott,
There is no minimum recommendation. The cover glass will impact the minimum resolution of the device so this is usually used to pick transmission based on the requirements.
resolution = (OPT resolution)/(transmission)
For example with OPT3001 in 800ms mode resolution is 10mLux. With 1% transmissive glass this give
minimum resolution = .01/.01 = 1 lux
Alex
