To analyze data with synchronous direct data burst, I used 12bit sampled data until now with SAMPLE_SEL=1. This works fine. But now I would like to test 8bit data with SAMPLE_SEL=0.
The descrition in the datasheet is not clear to me. Following you can see the datasheet description:
This are my questions:
1) What is meant by 'digital gain select'. There is no further explanation in the datasheet.
2) What is the difference betwenn LPF-Output and 'all others'.
3) The DP_MUX selects datapath, SAMPLE_SEL selects data width, but what selects LSB/MSB.
The only thing I could find with similar naming, are registers P1_GAIN_CTRL and P2_GAIN_CTRL for digital gain configuration.
These registers hold some settings which are named with DIG_GAIN_LR_ST, DIG_GAIN_LR, DIG_GAIN_SR.
But there is no similarity to 'digital gain select'.
