The mmWave DemoVisualizer, now in version 3.5, allows us to record data from the radar to a binary (.dat) file. However, there is no official tool to make this file useful. I have found an old script here for previous SDKs, that worked partially. However, sometimes it hits corrupted frames and dies. So I looked in the forums and found people with similar issues. I have also found an alternative for a newer, but still outdated, SDK. With these two scripts, I have managed to create a functional script for SDK 3.2. Note that I have focused on range profile extraction and did not try to implement the other functions.
My contribution is here:
import struct import sys import math import matplotlib.pyplot as plt import numpy as np import csv global csv_file; global make_plot; def tlvHeaderDecode(data): tlvType, tlvLength = struct.unpack('2I', data) return tlvType, tlvLength def parseRangeProfile(data, tlvLength): looper = int(tlvLength / 2) a = np.ones((256,1)) for i in range(looper): rangeProfile = struct.unpack('H', data[2*i:2*i+2]) a[i] = (rangeProfile[0] * 1.0 * 6.0 / 8.0 / (1 << 8))*10.0 #a[i] = rangeProfile[0] #print("\tRangeProf[%0.3fm]:\t%07.3fdB "%(i * 0.044, 20 * math.log10(2**(rangeProfile[0]/(2**9))))) #0.1249921875 is based on profile confg #print("\tTLVType:\t%d "%(2)) with open(csv_file, 'ab') as f: writer = csv.writer(f, delimiter=' ', quotechar='|', quoting=csv.QUOTE_MINIMAL) a.tofile(f, sep=',',format='%10.5f') writer.writerow('') if make_plot == True: plt.clf() plt.plot(a) plt.ylabel('Range Profile Zero') plt.draw() plt.pause(0.02) def tlvHeader(data, skip_range=False, skip_stats=False): pendingBytes = 29 headerLength = 28 a= 1 while(data): a=2 magic = b'\x02\x01\x04\x03\x06\x05\x08\x07' offset = data.find(magic) data = data[offset:] data = data[8:] try: version, length, platform, frameNum, cpuCycles, numObj, numTLVs = struct.unpack('<7I', data[:headerLength]) except struct.error as e: #print "Improper TLV structure found: ", (data,) print("Error ", e) print(pendingBytes) break print("Packet ID:\t%d "%(frameNum)) print("Version:\t%x "%(version)) print("TLV:\t\t%d "%(numTLVs)) print("Detect Obj:\t%d "%(numObj)) print("Platform:\t%X"%(platform)) #print("Subframe:\t%d "%(subFrameNum)) print "" pendingBytes = length - headerLength data = data[headerLength+4:] counter = 0; n= 3; for i in range(n): tlvType, tlvLength = tlvHeaderDecode(data[:8]) data = data[8:] if (tlvType == 3): # parseDetectedObjects(data, tlvLength) b = 2 # I have focused on range profile elif (tlvType == 2): if not skip_range: parseRangeProfile(data, tlvLength) b=2 elif (tlvType == 6): if not skip_stats: #parseStats(data, tlvLength) b=2 # I have focused on range profile #tlvLength = tlvLength + 4 b=2 else: #print("Unidentified tlv type %d"%(tlvType)) b=2 #as some corrupted frames ruin the plot, I am incremeting manually if counter == 0: data = data[512:] elif counter == 1: data = data[512:] elif counter == 2: data = data[24:] counter += 1 #data = data[tlvLength:] pendingBytes -= (8+tlvLength) if __name__ == "__main__": if len(sys.argv) < 2 or len(sys.argv) > 3: print("Usage: parseTLV.py inputFile.bin plot/no_plot") sys.exit() fileName = sys.argv[1] csv_file = fileName + ".csv" rawDataFile = open(fileName, "rb") rawData = rawDataFile.read() rawDataFile.close() if len(sys.argv) == 3: if sys.argv[2] == "no_plot": make_plot = False print "plot False" else: make_plot = True print "plot True" else: make_plot = True; print "ploe true" print ("make_plot %d" % make_plot) tlvHeader(rawData, skip_stats=True, skip_range=False)
