Does opt3001 have power on/off sequence?
After power on, how long does it take for waiting then I can do the first I2C command?
Thank you
Thank you
Hi David,
The application expert for this device, Alex, is on vacation and will be back on Jan 4.
He will respond to your queries when he returns.
Thanks for your patience and understanding.
Happy Holidays!
Hi David,
First I2C can be issued after the VDD supply to the device has stabilized.
Alex
Hi Alex,
May I double check that opt3001 doesn't need latency time for executing i2c cmd (read/write register) after vdd is set in operating voltage (ex: 1.8v)?
And I didn't find power on/off sequence on opt3001 datasheet. Does opt3001 have power on/off sequence?
Thank you
Hi David,
From supply stabilized to device operational should not take longer than 300us.
Can you clarify what you mean by power on/off sequence? Device is single supply so does not have any specific requirements in terms of power supply ordering.
Alex
Thanks Alex,
May I check that I don't need to control I/O pin after vdd power on for opt3001?
For example, interrupt. I have encountered that need to set interrupt (High/Low) in power on sequence in other IC.
Thank you
Hi David,
No INT setting is not part of power on seq but it can be controlled through the register settings.
Alex
