Other Parts Discussed in Thread: AWR2243
请问AWR2243这一款毫米波雷达传感器能否仅作为接收机使用?
Can awr2243 millimeter wave radar sensor only be used as a receiver?
Hello User,
May we understand your purpose of achieving this?
To answer your question, AWR2243 boost EVM has 3TX and 4RX with individual antenna ON/OFF programmability. For your purpose, you can disable all the TXs and just enable RX antennas in the Channel Config. If you're using mmWave studio, you can find this Channel configurability in the "Static Config" tab. Else, you can also refer to the mmWave ICD to program the concerned API.
Ishita
