[FAQ] FDC1004 Capacitive Sensing FAQs
Genius 17945 points
Part Number: FDC1004
 What are the differences between Capacitive Sensing Versus Capacitive Touch Solutions.
Texas Instruments provides solutions for capacitive sensing and capacitive touch applications, which share some important similarities and some crucial differences. Capacitive sensing applications can require relatively large target distances and/or higher resolution than capacitive touch applications.
The table below offers a brief comparison between the similarities and differences between these two applications
Requirements
Capacitive Sensing
Capacitive Touch
Channel count
Low (< 4)
High (> 8)
Resolution
High
Low
Typical distance
Up to 70 cm
2 to 3 mm
Sensitivity
< 1 fF
10s to 100s fF
Requires contact
No
Yes
Power consumption
μA range
μA to mA range
For more information on capacitive touch solutions, please consider TI's capTIvate as the best fit for this application.
        http://www.ti.com/microcontrollers/msp430-ultra-low-power-mcus/capacitive-sensing-mcus-overview.html
What applications can/can’t be supported by capacitive sensing?
  1. Liquid Level Sensing
    For most non-conductive liquid level sensing applications (including water), the FDC1004 should be used. The FDC1004 has an active shield driver which helps the system against interference from environmental factors.
  2. Non-Metal Proximity Sensing
    The FDC1004 is the best choice, since the FDC2x1x does not have a shield driver, can and requires advanced system level expertise.
  3. What applications do not work with TI's capacitive sensing technology?
    Metal detection - to detect metal, TI's inductive sensing solutions are a better option.
    See the TI E2E Inductive Sensing FAQ  Inductive Sensing FAQ
How do I get started with Capacitive Sensing?
A list of learning and design resources, sorted by subject, are given below.
Subject
App Note Title
App Note URL
Introductory App Notes
Common Inductive and Capacitive Sensing Applications
https://www.ti.com/lit/pdf/slya048
Basics of Capacitive Sensing with FDC1004
 https://www.ti.com/lit/pdf/snoa927
Liquid Level Sensing App Notes
Capacitive Sensing: Ins and Outs of Active Shielding
https://www.ti.com/lit/pdf/snoa926
Capacitive Sensing: Out-of-Phase Liquid Level Technique
https://www.ti.com/lit/pdf/snoa925
Capacitive Sensing: Direct vs Remote Liquid-Level Sensing Performance Analysis
https://www.ti.com/lit/pdf/snoa935
Liquid Level Sensing with the Immersive Straw Approach
https://www.ti.com/lit/pdf/snoa934
How to Calibrate FDC1004 for Liquid Level Sensing Applications
https://www.ti.com/lit/pdf/snoa958
Proximity sensing
Capacitive Proximity Sensing Using the FDC1004
https://www.ti.com/lit/pdf/snoa928
General App Notes, Technical Articles and Blogs
Derivative Integration Algorithm for Proximity Sensing
https://www.ti.com/lit/pdf/snoa939
Ground Shifting in Capacitive Sensing Applications
https://www.ti.com/lit/pdf/SNOA952
Power Reduction Techniques for the FDC2214/2212/2114/2112 in Capacitive Sensing Applications
https://www.ti.com/lit/pdf/SNOA943
Capacitive sensing: simple algorithm for proximity sensing
https://e2e.ti.com/BLOGS_/B/ANALOGWIRE/ARCHIVE/2015/11/23/CAPACITIVE-SENSING-SIMPLE-ALGORITHM-FOR-PROXIMITY-SENSING
Capacitive sensing: which architecture should you choose?
https://e2e.ti.com/blogs_/b/analogwire/archive/2015/10/20/capacitive-sensing-which-architecture-should-you-choose
TI Designs
Capacitive Based Liquid Level Sensing - TIDA-00317 (FDC1004 , MSP430F5528 )
http://www.ti.com/tool/TIDA-00317
Backlight and Smart Lighting Control by Ambient Light and Proximity Sensor Reference Design - TIDA-00373 (FDC1004 , HDC1000 , HDC1008 )
https://www.ti.com/tool/TIDA-00373
Automotive Capacitive Proximity Kick to Open Detection Reference Design TIDA-00506 (FDC1004)
https://www.ti.com/tool/TIDA-00506
Capacitive-Based Human Proximity Detection for System Wake-Up & Interrupt Reference Design - TIDA-00220 (FDC1004 , LM3630A , LP5907 )
https://www.ti.com/tool/TIDA-00220
EVMs
FDC1004EVM - 4 Channel Capacitive to Digital Converter Evaluation Module
https://www.ti.com/tool/FDC1004EVM
Software
Capacitive Sensing Sample Code (Energia)
http://www.ti.com/lit/zip/snvc187
Sensing Solutions EVM GUI Tool
http://www.ti.com/lit/zip/snoc028
What are the differences between the FDC1004 and the FDC2212/2214?
The table below shows & compares the major features of the two devices.
FDC1004
FDC2212/2214
Number of Channels
4
2 or 4
Architecture
Switched Cap
Resonant LC Tank
Supply Voltage
3.3
3.3
I active
0.95mA
2.1mA
Sensor Current
0
6mA
Sensor driving Frequency
25 kHz
0.1Mhz - 10 MHz
Maximum Sensor Input
115pF
250nF @ 10Khz / 25pF @ 10 MHz
Sensor input range w/respect to input offset calibration
±15pF
NA
Input Offset Calibration
100pF
N/A
Integrated Shield Driver
400pF
N/A
Driver Architecture
Continuous CLK driver
Discontinuous Sin Driver
Effective resolution
16 bits
12/28 bits depending on the LC frequency
Gain error
0.20%
N/A
Gain Error over temp
37.5 ppm/C
Depends on External LC
DC PSRR
13.6fF/V
N/A
EMI
Better
Poor, needs external passives
Configurability
Contained
High SW and HW
Package
QFN/TSSOP
QFN
  • As the table shows, the FDC1004 input is a switch-cap topology while the FDC2x12/4 uses a resonant tank. The major advantages of the FDC1004 is its integrated shield driver, which can improve the EMI/noise immunity of your circuit, and its driver architecture, which greatly reduce EMI emissions, compared to the FDC2x12/4.
FDC1004 frequently asked questions:
  • When is the FDC1004 a bad fit for my liquid level sensing application?
    The FDC1004 does not work with conductive liquid. The FDC1004 works well for most other liquid level sensing applications, including water. For more information, see the topic Liquid Level Sensing App Notes above for a list of supporting app notes.
  • Should I use a single-ended or a differential measurement?
    Both options work can work for liquid level sensing. The advantage of the differential measurement is that it helps with immunity to environmental conditions. For more information please see the app note Capacitive Sensing: Out-of-Phase Liquid Level Technique https://www.ti.com/lit/pdf/snoa925
  • Can the FDC1004 be used for proximity sensing applications?
    The FDC1004 can be used for proximity detection, and detection of simple gestures. For more information on using the FDC1004 for proximity detection, please see the app note Capacitive Proximity Sensing Using the FDC1004 https://www.ti.com/lit/pdf/snoa928 , or the reference designs https://www.ti.com/tool/TIDA-00506 & https://www.ti.com/tool/TIDA-00220
 Capacitive sensing applications with the FDC1004 include:
1. Independent channels
The FDC1004 features 4 independent channels that are sampled sequentially in a time-multiplexed manner. Typical applications include rain sensing, proximity/gesture detection, and water/ice/snow detection.
Figure 1. Independent Channel use Case for Gesture Sensing Application
2. Differential or ratio-metric measurements
Differential measurements are performed to obtain an accurate capacitance measurement difference between two sensors. This is most applicable to environmental factors that can cause variations in capacitance, such as direct, immersive sensing, or remote liquid sensing.
 Figure 2. Differential or Ratiometric Measurements Example, Liquid Level
3. Remote sensing
Physical distances between the sensor and the device can be a major issue when accurate capacitive measurements are needed. To compensate for long signal paths, the FDC1004 allows parasitic capacitance compensation up to 100 pF which gives the FDC1004 the ability to drive a twisted pair up to 1600 m (60 fF/m) or a coax cable up to 1.5 m (66 pF/m).
Figure 3. Remote Sensing Example
4. Time-varying offset measurements
The FDC1004 can be used in the case where time-varying offset measurements are required to be monitored. A replica sensor adjusts for changes in offset from factors like humidity, environment, and water/ice/snow.
Figure 4. Time-Varying Offset Measurements Example
John Miller
Sensing Applications Engineer
