Other Parts Discussed in Thread: AWR2243, AWR1443, , AWR1243, AWR1642, AWR6843
Hello!
I'm looking at the different AWR chips and trying to determine which one best meets my needs. I was able to collect most the info I needed from the datasheets but wanted to double check/clarify a few things.
I'm trying to sync multiple boards together and it appears that only the AWR2243 has the cascade sync support (and has a dedicated cascade board to assist with this), but what I'm currently interested in is which chips/boards support frame sync. The AWR1243 and AWR1443 both specifically call out that they have frame sync support, I found one forum post that suggests the AWR1843 does support it at the following location:
Is someone able to confirm that each of these chips support frame sync? I assume they do but wanted to confirm before moving forward with this.
AWR1243 | AWR1443 | AWR1642 | AWR1843 | AWR2243 | AWR6843 | |
Frame Sync Support | Yes | Yes | ? | ? | Yes | ? |
Cascade Sync Support | No | No | No | No | Yes | No |
Realistically, the chips I'm looking at are the AWR1643 and the AWR1843 so those are the two I'm most concerned with answering this question for but, at this point, I might as well finish updating my chip comparison chart while I'm at it.
Any info you can point me to would be greatly appreciated!
