[FAQ] FDC2x1x Capacitive Sensing FAQs
Other Parts Discussed in Thread: FDC1004, FDC2214, LDC1101, LDC1612, LDC1312, TIDA-00317, TIDA-00373, TIDA-00506, TIDA-00220, TIDA-01409, TIDA-00466, FDC1004EVM, FDC2114EVM, FDC2114, FDC2214EVM, ENERGIA, FDC2212, FDC2112
 For additional information, please see the FDC1004 Capacitive Sensing FAQs: https://e2e.ti.com/support/sensors/f/1023/t/976381
What are the differences between Capacitive Sensing Versus Capacitive Touch Solutions.
Texas Instruments provides solutions for capacitive sensing and capacitive touch applications, which share some important similarities and some crucial differences. Capacitive sensing applications can require relatively large target distances and/or higher resolution than capacitive touch applications.
The table below offers a brief comparison between the similarities and differences between these two applications
Requirements
Capacitive Sensing
Capacitive Touch
Channel count
Low (< 4)
High (> 8)
Resolution
High
Low
Typical distance
Up to 70 cm
2 to 3 mm
Sensitivity
< 1 fF
10s to 100s fF
Requires contact
No
Yes
Power consumption
μA range
μA to mA range
For more information on capacitive touch solutions, please consider TI's capTIvate as the best fit for this application.
·         http://www.ti.com/microcontrollers/msp430-ultra-low-power-mcus/capacitive-sensing-mcus-overview.html
What applications can/can’t be supported by capacitive sensing?
  1. Liquid Level Sensing
    For most non-conductive liquid level sensing applications (including water), the FDC1004 should be used. The FDC1004 has an active shield driver which helps the system against interference from environmental factors.
  2. Non-Metal Proximity Sensing
    The FDC1004 is the best choice, since the FDC2x1x does not have a shield driver, can and requires advanced system level expertise.
  3. What applications do not work with TI's capacitive sensing technology?
    Metal detection - to detect metal, TI's inductive sensing solutions are a better option.
    See the TI E2E Inductive Sensing FAQ  Inductive Sensing FAQ
How do I get started with Capacitive Sensing?
A list of learning and design resources, sorted by subject, are given below.
Subject
App Note Title
App Note URL
Introductory App Notes
Common Inductive and Capacitive Sensing Applications
https://www.ti.com/lit/pdf/slya048
Basics of Capacitive Sensing with FDC1004
 https://www.ti.com/lit/pdf/snoa927
Liquid Level Sensing App Notes
Capacitive Sensing: Ins and Outs of Active Shielding
https://www.ti.com/lit/pdf/snoa926
Capacitive Sensing: Out-of-Phase Liquid Level Technique
https://www.ti.com/lit/pdf/snoa925
Capacitive Sensing: Direct vs Remote Liquid-Level Sensing Performance Analysis
https://www.ti.com/lit/pdf/snoa935
Liquid Level Sensing with the Immersive Straw Approach
https://www.ti.com/lit/pdf/snoa934
How to Calibrate FDC1004 for Liquid Level Sensing Applications
https://www.ti.com/lit/pdf/snoa958
Proximity sensing
Capacitive Proximity Sensing Using the FDC1004
https://www.ti.com/lit/pdf/snoa928
Capacitive Proximity Sensing Using FDC2x1y
https://www.ti.com/lit/pdf/snoa940
General App Notes, Technical Articles and Blogs
Derivative Integration Algorithm for Proximity Sensing
https://www.ti.com/lit/pdf/snoa939
Ground Shifting in Capacitive Sensing Applications
https://www.ti.com/lit/pdf/SNOA952
Power Reduction Techniques for the FDC2214/2212/2114/2112 in Capacitive Sensing Applications
https://www.ti.com/lit/pdf/SNOA943
Capacitive sensing: simple algorithm for proximity sensing
https://e2e.ti.com/BLOGS_/B/ANALOGWIRE/ARCHIVE/2015/11/23/CAPACITIVE-SENSING-SIMPLE-ALGORITHM-FOR-PROXIMITY-SENSING
Capacitive sensing: which architecture should you choose?
https://e2e.ti.com/blogs_/b/analogwire/archive/2015/10/20/capacitive-sensing-which-architecture-should-you-choose
Inductive Sensing App Notes with Useful Info for Capacitive Sensing Circuits using the FDC2x1y
Measuring Rp of an L-C Sensor for Inductive Sensing
https://www.ti.com/lit/pdf/snoa936
Optimizing L Measurement Resolution for the LDC161x and LDC1101
https://www.ti.com/lit/pdf/snoa944
Setting LDC1312/4, LDC1612/4, and LDC1101 Sensor Drive Configuration
https://www.ti.com/lit/pdf/snoa950
TI Designs
Capacitive Based Liquid Level Sensing - TIDA-00317 (FDC1004 , MSP430F5528 )
http://www.ti.com/tool/TIDA-00317
Backlight and Smart Lighting Control by Ambient Light and Proximity Sensor Reference Design - TIDA-00373 (FDC1004 , HDC1000 , HDC1008 )
https://www.ti.com/tool/TIDA-00373
Automotive Capacitive Proximity Kick to Open Detection Reference Design TIDA-00506 (FDC1004)
https://www.ti.com/tool/TIDA-00506
Capacitive-Based Human Proximity Detection for System Wake-Up & Interrupt Reference Design - TIDA-00220 (FDC1004 , LM3630A , LP5907 )
https://www.ti.com/tool/TIDA-00220
Automotive Capacitive Kick-to-Open Reference Design - TIDA-01409
(FDC2212-Q1 , SN74LVC1G04-Q1 , TPS7B69-Q1 )
https://www.ti.com/tool/TIDA-01409
Noise-immune Capacitive Proximity Sensor System Reference Design - TIDA-00466
(FDC2212 , FDC2214 , CSD25310Q2 )
https://www.ti.com/tool/TIDA-00466
EVMs
FDC1004EVM - 4 Channel Capacitive to Digital Converter Evaluation Module
https://www.ti.com/tool/FDC1004EVM
FDC2114EVM - FDC2114 with Two Capacitive Sensors Evaluation Module
https://www.ti.com/tool/FDC2114EVM
FDC2214EVM - FDC2214 with Two Capacitive Sensors Evaluation Module
https://www.ti.com/tool/FDC2214EVM
Software
Capacitive Sensing Sample Code (Energia)
http://www.ti.com/lit/zip/snvc187
Sensing Solutions EVM GUI Tool
http://www.ti.com/lit/zip/snoc028
FDC211x/FDC221x Current Consumption Estimator
http://www.ti.com/lit/zip/snoc033
What are the differences between the FDC1004 and the FDC2212/2214?
The table below shows & compares the major features of the two devices.
FDC2212/2214
FDC1004
Number of Channels
2 or 4
4
Architecture
Resonant LC Tank
Switched Cap
Supply Voltage
3.3
3.3
I active
2.1mA
0.95mA
Sensor Current
6mA
0
Sensor driving Frequency
0.1Mhz - 10 MHz
25 kHz
Maximum Sensor Input
250nF @ 10Khz / 25pF @ 10 MHz
115pF
Sensor input range w/respect to input offset calibration
NA
±15pF
Input Offset Calibration
N/A
100pF
Integrated Shield Driver
N/A
400pF
Driver Architecture
Discontinuous Sin Driver
Continuous CLK driver
Effective resolution
12/28 bits depending on the LC frequency
16 bits
Gain error
N/A
0.20%
Gain Error over temp
Depends on External LC
37.5 ppm/C
DC PSRR
N/A
13.6fF/V
EMI
Poor, needs external passives
Better
Configurability
High SW and HW
Contained
Package
QFN
QFN/TSSOP
  • As the table shows, the FDC1004 input is a switch-cap topology while the FDC2x12/4 uses a resonant tank. The major advantages of the FDC1004 is its integrated shield driver, which can improve the EMI/noise immunity of your circuit, and its driver architecture, which greatly reduce EMI emissions, compared to the FDC2x12/4.
FDC2x1x frequently asked questions:
  • When is the FDC2x1x a bad fit for my capacitive sensing application?
     The FDC2x1x family of devices uses a resonant LC tank topology instead of the traditional switched capacitor architecture. It also does not include a dedicated shield driver pin. For this reason, usually FDC1004 is the better choice for liquid level sensing applications. For other types of capacitive sensing, TI's capTIvate family is the better choice.
    The main challenges for the FDC2x1x are:
  1. Requires an external inductor for each channel.
  2. Poor EMI/EMC performance
  3. Difficult to tune for different systems
  • Can the FDC2x1x be used for proximity detection?
    The FDC2x1x family of devices can be used for proximity detection, with the caveats discussed just above. For more information, please see the app note Capacitive Proximity Sensing Using FDC2x1y, https://www.ti.com/lit/pdf/snoa940
  • Which FDC2x1x device should I use?
  1. Determine the number of channels needed for your system
  2. For precision applications, start with the FDC221x family of devices for initial evaluation. The FDC211x, lower resolution devices are pin for pin compatible and can be tested after suitability with the higher resolution device is proven.
FDC2212
FDC2112
FDC2214
FDC2114
Resolution
28 bits
12 bits
28 bits
12 bits
Number of channels
2
2
4
4
  • What is the effective resolution of the FDC221x?
    While the following app note focuses on inductive sensing: http://www.ti.com/lit/pdf/snoa944.
    The concepts explained for the LDC161x devices also apply to the FDC221x.
  • How do I choose the IDRIVE setting for the FDC2x1x?
    While the following app note focuses on inductive sensing (http://www.ti.com/lit/pdf/snoa950), the concepts explained for the LDC161x and LDC131x also apply to the FDC2x1x.
  • How can I improve EMI/EMC performance with the FDC2x1x?
    The passive filtering and supply/return routing recommendations from the following app note are applicable to the FDC2x1x:   http://www.ti.com/lit/an/snoa962/snoa962.pdf
  • How can the FDC2x1x power consumption be reduced?
    Device power consumption can be reduced with duty-cycling and clock-gating techniques. Details are available in the app note Power Reduction Techniques for the FDC2214/2212/2114/2112 in Capacitive Sensing Applications https://www.ti.com/lit/pdf/SNOA943
